ISDN problem
Answered Question
May 8th, 2008
I have this configuration on a bri interface
interface BRI4/3
description …………………
bandwidth 128
ip address 10.0.1.69 255.255.255.252
encapsulation ppp
dialer idle-timeout 2147483
dialer map ip 10.0.1.70 name ……….. broadcast …….
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
no fair-queue
(The other side similar)
1. I put under the configuration the command ppp multilink. It seems that the WAN link is faster. Is that normal.I checked it with PTRG (ping latency)
2. Also i've read that instead of using load-threshold 1 is better to use not less than 3 . Is that true?
Thanks a lot
moses
Correct Answer by shillyar about 9 years 2 months ago
Hi Moses,
When you add ppp multil link you are basically bundling both b channels together instead of 1 or 2 individual b channels. Multilink forms 1 big pipe with both channels so yes the ping should be faster.
As for the load-throsold 1 is fine just stay away from 0. A for teh difference between 1 and 3 id say you would not even notice as the load throsold will determin when that 2nd channce some up in terms of load. if you set it at 1 it will pretty much come up rightaway depending on your load. If you worried about costs then dont set it at 1 unless you really need to and have the speed and load up most of the time.
Thx steve
Overall Rating: 5 (2 ratings)
Correct Answer
shillyar Thu, 05/08/2008 - 09:16
  • Cisco Employee,
Hi Moses,
Thx steve
