Cisco IP communicator
May 8th, 2008
Hi All,
I've installed ip communicator in the labtop, after restarting the labtop, and running ip communicator, I've got error message "audio device is not compatible". Then I've tried different versions of communicator but the same error message. Is there anyway to fix this issue?
thanks
Alex
Paolo Bevilacqua Thu, 05/08/2008 - 09:05
  • Hall of Fame,
    Founding Member
Right click and go preferences, audio, select either device or "default windows". If still doesn't work, I wouldn't be able to say why.
Paolo Bevilacqua Thu, 05/08/2008 - 09:17
  • Hall of Fame,
    Founding Member
Anywhere on the screen if it starts. If it doesn't, I would not know what to suggest.
alex goshtaei Thu, 05/08/2008 - 11:03
I read in troubleshoot document, it says download Cisco IP communicator Administration tool in the same site for software. I couldn't find Administration Tool. Do you know where I can download this tool?
thanks
Alex
Jaime Valencia Thu, 05/08/2008 - 16:17
  • Cisco Employee,
  • Hall of Fame,
    2011
not sure why you need that, i'd follow Paolo's recommendation of going into the preferences to check the audio device selected. but if you want to know it's in the zip file you already have for CIPC, when you unzip it the file should be in there.
javalenc
if this helps, please rate
