05-08-2008 08:32 AM
Hello all got this error message on the server info page.. any ideas? thanks
Can't locate loadable object for module perlDbEncrypt in @INC (@INC contains: C:\PROGRA~1\CSCOpx/bin C:\PROGRA~1\CSCOpx/lib C:\PROGRA~1\CSCOpx/lib/perl/db C:\PROGRA~1\CSCOpx/lib/perl/install C:\PROGRA~1\CSCOpx/bin C:\PROGRA~1\CSCOpx/lib/perl/db C:\PROGRA~1\CSCOpx/lib/perl/db C:\PROGRA~1\CSCOpx\objects\perl5\lib/MSWin32-x86 C:\PROGRA~1\CSCOpx\objects\perl5\lib C:\PROGRA~1\CSCOpx\lib C:\PROGRA~1\CSCOpx\objects\perl5\site\lib/MSWin32-x86 C:\PROGRA~1\CSCOpx\objects\perl5\site\lib C:\PROGRA~1\CSCOpx\site\5.00502\lib C:\PROGRA~1\CSCOpx\site\lib . C:\PROGRA~1\CSCOpx/objects/perl/lib C:\PROGRA~1\CSCOpx/cgi-bin/dbadmin/pdbadmin C:\PROGRA~1\CSCOpx/objects/db C:\PROGRA~1\CSCOpx/lib C:\PROGRA~1\CSCOpx/bin) at C:\PROGRA~1\CSCOpx/lib/perl/db/Cisco/DbUtils.pm line 72
BEGIN failed--compilation aborted at database.pl line 20.
05-08-2008 08:50 AM
What version of LMS is this?
05-08-2008 09:28 AM
LMS 2.6
05-08-2008 11:32 AM
The file NMSROOT\objects\perl5\site\lib\perlDbEncrypt.pm must exist on your system, and have permissions for casuser. If this is not the case, your installation has been damaged.
05-09-2008 11:25 AM
I have it with the rights, whats next reinstall? 97% of LM works and one file is killing me...any way to repair it? thanks
05-09-2008 11:35 AM
Honestly, self test is 100% useless. I never ask customers to provide it, and I never trust what it says. So if everything else is working, you are probably okay to ignore this.
That said, this could still be symptomatic of a larger problem. Verify that NMSROOT\bin\perlDbEncrypt.dll exists and has proper permissions.
05-09-2008 11:53 AM
Yeah 98% of LM works, My backups and purges have issues..it is a old install without alot of patches so I might start over with it.. thanks for your help
05-09-2008 12:01 PM
Backups use Perl, and are VERY important. If that DLL is missing or damaged, you should consider reinstalling all of LMS to repair the problem.
