Reports on Cisco CallManager
May 8th, 2008
Is there a way to run reports on callmanager that would give statistics for a specific time frame, basically we are looking for call volumes, average incoming and average outgoing call volume for specific dates.
Overall Rating: 5 (2 ratings)
Jaime Valencia Thu, 05/08/2008 - 11:23
  • Cisco Employee,
  • Hall of Fame,
    2011
the CAR reports let you configure a timeframe, isn't that working??
of course they won't give you stats but they certainly will give you info from a certain timeframe you choose
javalenc
if this helps, please rate
gonzalezel Thu, 05/08/2008 - 11:49
The only thing I get under CAR are the tabs BILLS, HELP, and LOGOUT. Does this mean the application isn't installed?
Jaime Valencia Thu, 05/08/2008 - 12:01
  • Cisco Employee,
  • Hall of Fame,
    2011
are you using a CAR admin account to login??
if not you're only getting your personal options, only for your user
javalenc
gonzalezel Thu, 05/08/2008 - 12:04
no just the callmanager login account, how would I create a CAR admin account?
gonzalezel Thu, 05/08/2008 - 12:10
CM Version 4.1(3)sr6
Admin version 4.1(0.11)
CM Installation id 4.1(3)sr6
Jaime Valencia Thu, 05/08/2008 - 12:19
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to log into CAR using admin/admin if it's the 1st time you login and add users to the admin group
javalenc
gonzalezel Thu, 05/08/2008 - 12:26
unfortunately that does not work, the person who was here before is now gone from the company. Is there a way to reset it or break in as no one knows the useraname and password.
Jaime Valencia Thu, 05/08/2008 - 12:35
  • Cisco Employee,
  • Hall of Fame,
    2011
if you know the user you can reset the pwd on the directory
javalenc
Rob Huffman Thu, 05/08/2008 - 12:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Efrain,
Hope things are good with you! Here is a note to add to the great help from Jaime (nice work here my friend :) 5 points for your good follow-up)
This doc has some good detailed steps for what you need to do;
Cisco CallManager: Restoring a Lost ART / CAR Password
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801115eb.shtml
Hope this helps!
Rob
gonzalezel Fri, 05/09/2008 - 07:43
Ok that worked, but now I when I do a search by any extension all I get is zeros or empty reports. Any ideas?
