NTP
May 8th, 2008
i have a BITS hw clocking device , from where i will be getting clock on an E1. I want to configure it for a cisco router, so that the cisco router will be using that BITS Hardware device as its clocking source.
Cisco router in 7200 and 2821.
How can it be possibel ??
yjdabear Thu, 05/08/2008 - 10:26
NTP has nothing to do with the clocking on the T1/E1 lines. The latter is usually provided by the carrier that supplies the circuits. Any reason you don't want to use theirs?
munawar.zeeshan Thu, 05/08/2008 - 11:13
infect my engineering department has that BITS clocking he device.They are providing me it via an E1.
I want to use clocking for log generation and other such purposes on my cisco routers and switches.
Any other option you people can propose ??
yjdabear Thu, 05/08/2008 - 11:30
Well, as long as the BITS device supports NTP and is reachable by IP, I suppose:
ntp server ip-addr-of-BITS-clock prefer
ntp server other-NTP-clock
ntp update-calendar time-zone
clock timezone zone GMT-offset [minutes-offset]
clock summer-time [your-daylight saving-time-zone] recurring
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
