Routing protocol questions: here, or the LAN forum?
May 8th, 2008
  • Bronze, 100 points or more
See, they've got this WAN Routing & Switching Forum; as well as a LAN Routing & Switching Forum; and I'm thinkin' if you've just got a general conceptual question about a routing protocol, that isn't dependent on whether the network is a WAN or a big ol' routed LAN, which of the two forums should you post it in?
I pose this identical question in the other forum as well.
Richard Burts Thu, 05/08/2008 - 10:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Seth
If the question is general about routing protocols then you could post in either forum. You will get much the same people responding in each one of these forums.
I would encourage you to not post the same question in both forums - especially not at about the same time. If you post in one forum, give it a while and see what responses you get before you post in the other forum.
Rick
