CME interfacing another CME
Answered Question
May 8th, 2008
Hi guys,
Originally we had one CME in the network supporting 48 phones. Due to a change order the total number of phones jumped to 78. So we decided to add another CME to the network.
The 2 CMEs are connected to a cisco switch. Both CMEs are on the same VLan. I'm having some problems to interface both CMEs. I know about dial-peer, but it doesn't seem working here since the 2 CMEs are on the same switch and same VLAN. Any ideas of how to solve this problem?
Correct Answer by Paolo Bevilacqua about 8 years 5 months ago
Hi, all good but please don't change the value of dscp media from the standard of EF.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 05/09/2008 - 12:26
Hi have you ever looked at the cisco documentation? search for example "dial-peer voip".
valides007 Fri, 05/09/2008 - 13:52
i know dial-peer command and i have used it before, but here there is no router interfacing the 2 CMEs. Basically they are on the same switch and same VLAN, so "session-target ipv4:" commnand doesn't seem working. I think it's obvious since i only have layer 2 here.
hope you understand what i'm saying!
Paolo Bevilacqua Fri, 05/09/2008 - 14:03
That should work. set codec g711u and no vad, also set incoming-called number xxx for the numbers you receive calls for.
Also if you set session protocol sipv2 under DP, it's easy to see what happens with "debug ccsip message" and "term mon".
lwai Sun, 05/11/2008 - 18:35
You should define the follow to allow connections between the two CME, and define dail-peer voice.
I suppose the extensions of phone sets are 7XXX.
voice service voip
voice rtp send-recv
dial-peer voice 200 voip
destination-pattern 7...
session target ipv4:10.xx.xx.xx
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
Correct Answer
Paolo Bevilacqua Mon, 05/12/2008 - 00:30
