Team servers connected to a css11501S
May 8th, 2008
I have 2 CSS11501S connected to an stateful active/standby pair on port e8. And servers with one nic in each CSS. So CSS01 e1 has NIC1 of serverA and CSS02 e1 has NIC2 of serverA. I had some issues where the VIPs would not work because VRRP wouldnt work (each CSS couldnt see eachother) I resolved that by making e7 a trunk and got the VRRP working in a active standby(stateful) setup between the CSS. PRoblem is now that the Teamed servers crap out when more than one nic is turned on. If i put on both nics then they dont work they just die. If i turn off a nic then it works. I'm a bit confused since the trunk should be able to allow the nics to communicate with eachother.
Any insight would be helpful
santosengineer Fri, 05/09/2008 - 06:09
ahh found the answer.. seems that the content switch behaves a bit erratically with an active/active teaming. When they are on active/standby there are no issues.
