Most likely a silly question about EtherChannels
Answered Question
May 8th, 2008
Ok, here goes. I am being asked to possibly create an etherchannel in this topo
Switch 1 connects to switch 2 via gig link
Switch 1 connect to switch 3 via 100mb link
Switch 2 connect to switch 3 via gig link
I don't believe it is possible, but the request is to connect switch 1 to the two remote switches via etherchannel. Because the connections from switch 1 are terminating on two different switches and are two different bw's I don't believe this is possible. But, I am wondering if anyone has seen something similar to this and if there is a way to make it work?
Correct Answer by gpulos about 8 years 11 months ago
You're correct,
You cannot create an etherchannel with two dissimilar Link Speeds or Media Types.
You can create two separate etherchannels. One from SW1 >> SW2 with 2-8 1gb ports &
One from SW1 >> SW3 with 2-8 100mb ports
Please see the following link for more information on etherchannel:
http://www.cisco.com/en/US/tech/tk389/tk213/tsd_technology_support_protocol_home.html
Overall Rating: 5 (1 ratings)
Correct Answer
gpulos Thu, 05/08/2008 - 13:54
  • Blue, 1500 points or more
You're correct,
