IP Phones 7906 & 7911 not supported by CCM 4.1(3) ?
Answered Question
May 8th, 2008
I'm using a CCM 4.1(3) and i cannot register IP Phones 7906 & 7911. These are not available in 'Phone type drop-down list'. Is this CCM 4.1(3) can be upgrade to support these phones ? which patch ? how ?
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Dominique,
No need to uninstall my friend :) Just install the new one and you should be good to go. Once that has been completed the 7906 will be available on the Device Defaults page.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 05/08/2008 - 20:05
  • Cisco Employee,
  • Hall of Fame,
    2011
here you have the minimum requirements:
Cisco Unified IP Phone 7906G and 7911G Release Notes for Firmware Release 7.2(3) for Cisco Unified CallManager 4.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7906g_7911g/firmware/7_2_3/english/release/notes/11R723sc.html
Supported CallManager Versions
This Cisco Unified IP Phone 7906G and 7911G firmware release is supported with the following Cisco Unified CallManager versions. If you are running Cisco Unified CallManager release 3.0, 3.1, or 3.2, you must upgrade to Cisco Unified CallManager release 3.3(5) or later before you install this firmware release.
•Cisco Unified CallManager version 3.3(5) SR1 or later
•Cisco Unified CallManager version 4.0(2a) SR2b or later
•Cisco Unified CallManager version 4.1(3) SR1 or later
and also you need ciscocm.4-1-DevPack-25.3.exe, or later
all the info is on the link
javalenc
if this helps, please rate
dom.a Fri, 05/09/2008 - 15:35
This patch ciscocm.4-1-DevPack-25.3.exe installed on the CCM4.1 lists only IP Phones 7911 not 7906.
Do I nedd to find for a new patchs ?
Regarsd
Jaime Valencia Fri, 05/09/2008 - 15:41
  • Cisco Employee,
  • Hall of Fame,
    2011
you can try installing the latest one, do you have all the requirements from the link???
javalenc
Rob Huffman Fri, 05/09/2008 - 15:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dominique,
You can use Cisco Unified CallManager Device Package 4.1(65.0)with any 4.1(3) version above 4.1(3)sr1. This will add support for the 7906 as well as some other models;
Here is the link (needs CCO Login);
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-41
Hope this helps!
Rob
EDIT: Jaime, you have beaten my inept typing skills once again my friend ;-)
dom.a Sat, 05/10/2008 - 16:03
Thanks, do i need to uninstall the previous one already installed ?
Correct Answer
Rob Huffman Sat, 05/10/2008 - 17:01
  • Hall of Fame,
    Founding Member
Hi Dominique,
Hope this helps!
Rob
