uccx menu option/reporting
May 8th, 2008
we are using uccx 5 enhanced and have a simple aa script which offers a menu up to the caller. Is there a way that we can report on the options that the callers choose from the menu?
Thanks in advance.
~Jeff
pklos Fri, 05/09/2008 - 06:25
  • Silver, 250 points or more
You can put user's choice into enterprise data variable and then report basing on it.
regards,
PK
Jeff Thompson Fri, 05/09/2008 - 08:50
Thank you for the reply. forgive me, I am a little new to uccx. So if I understand you correctly, I would insert 'Get Enterprise Call Info' under say option 1 (as well as option 2, 3 ect..) where I am doing a 'Call Redirect' to an extension. Then I could use Historical reporting to report on that Variable??
I have tried using 'Set Contact Info' to 'Handled' though again, I am not sure where/how to report on that. maybe I don't have that in the correct spot within the script.
Any further help/example would be greatly appreciated.
~Jeff
