05-08-2008 08:06 PM - edited 03-03-2019 09:52 PM
Dear all,
I would like to ask you some question about flash 64MB, so when we buy router 1841 by default it had flash 32MB, so i order one more flash is 64MB for replace 32MB. when i replace it is login to rommon. this is message : System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
boot: cannot determine first executable file name on device "flash:"
PLD version 0x10
PLD version 0x10
rommon 1 >
I had to changed many flash already but still has the same?
So do you have advice for me or any command on a flash ?
Best Regards,
Norung
05-08-2008 08:25 PM
05-09-2008 06:55 PM
Dear sir,
I did not see your attach file.
Could you send me again?
one more i would like to ask you some question :
i saw on router it has 2 USB, so i would like to know how can it do on USB ?
Best Regards,
