Cisco 878 Urgent Help
May 8th, 2008
Guys i have one 3350 switch and two routers cisco 878.....the routers are attached to the swicth via LAN (layer 2) ports of the router (which is builin) now i have created 2 vlans 10,11 on the 3350 swicth and assigned the port to it (which connects the routers) now i want to ping one router from other (different Vlans) can someone please tell m ehow it will be as the swicth port in the router is layer two i cant assignm IP address and my design required that the router shd connect to the swicth via layer 2 port which is builtin???? what shd i do can someone please help
Jon Marshall Thu, 05/08/2008 - 23:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Please see answer in Lan switching and routing forum.
Jon
americain Fri, 05/09/2008 - 10:04
Hello
If you configure the vlan interface on the 878 it should work.
Even on a 828 you can configure an IP address on the LAN interface.
Frederic
