C2960 port loop disable ports
Answered Question
May 9th, 2008
We had a problem with a C2960.
Someone grab a cable and added to two switch port in the same switch.
The switch disable our other two trunk ports with udld configure.
How do I configure the switch to disable only the two loop port and not the trunk ports?
//Jan
Another way - would be:-
spanning-tree portfast bpduguard default, this will disable the specific port where the loop was deteted.
And to save you time, checking the ports and re-enabling them after a loop has been removed:-
errdisable recovery cause bpduguard
errdisable recovery cause udld
errdisable recovery interval ## (seconds)
HTH.
Overall Rating: 5 (2 ratings)
Pravin Phadte Fri, 05/09/2008 - 02:37
  • Silver, 250 points or more
If the ports are not been used. Then the best way would be to admin shut them.
Correct Answer
HTH.
Jan Rockstedt Fri, 05/09/2008 - 02:54
No solution, we need to have the port up.
How can we setup the switch to only disable the user port and not the trunk port?
-J-
Pravin Phadte Fri, 05/09/2008 - 03:11
If you can recrete the problem try to
configure port security in one of the option and find out which one would help.
Switch)# config t
Switch(config)# int fa0/10
Switch(config-if)# switchport port-security ?
aging Port-security aging commands
mac-address Secure mac address
maximum Max secure addresses
violation Security violation mode
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/port_sec.html
let me know if this does help
