Warning message
Passing multiple values using BGP
May 9th, 2008
I would like to know if it is posible to pass multiple values from one eBGP peer to another - i.e. with something similar to extended communities?
I.e. can an upstream peer pass 6 variables to the downstream peer for processing and making a route decision?
The only mechnism i can think of is extended communities and it's not possible to do it with this.
Thanks.
Joseph W. Doherty Fri, 05/09/2008 - 04:15
Would the BGP command set community {community-number [additive]}, using the additive option serve your need?
carl.forbes Fri, 05/09/2008 - 04:29
Hmm, i don't think so. From what i understand of the additive option, it would appear to add an additional community in transit.
I would like to add e.g. 6 community variables at the same time and send them to the downsream peer.
Thanks for this though, I haven't come across 'additive' before but now i have more confidence that BGP can handle multiple community values - but how do you write them all at the same time?
Thanks.
Joseph W. Doherty Fri, 05/09/2008 - 05:00
"but how do you write them all at the same time? "
Good question. Perhaps multiple set community additive commands within a route map, e.g. 6 in your case; unsure whether this is supported.
rais Fri, 05/09/2008 - 06:47
  • Silver, 250 points or more
So setting community multiple times in a route-map is not an option?
route-map rm permit 10
match ip address 10
set community 1:100
set community 1:101
set community 1:102
Thanks.
carl.forbes Fri, 05/09/2008 - 07:01
I wasn't aware it was possible to do this, thanks, but leads me to another question. For the upstream peer receiving this update - is it possible to index each value individually. E.g.:
comm 1:100 = value [1]
comm 1:101 = value [2]
comm 1:102 = value [3]
So at the upstream, can i use syntax similar to reg exp within a route map and do: if value [2] = 101, route packet via int x?
Harold Ritter Fri, 05/09/2008 - 07:07
  • Cisco Employee,
Carl,
You can do that as follow:
router bgp xx
neighbor x.x.x.x remote-as yyy
neighbor x.x.x.x route-map test out
neighbor x.x.x.x send-community
route-map test permit 10
set community 1:1 1:2 1:3 1:4 1:5 1:6
