05-09-2008 04:55 AM - edited 03-15-2019 10:33 AM
Hi guys. I have a CME 4.1 system with a SIP trunk for outside lines to my ISP/telephony provider. Everything works great except call forwards. The system forwards the call but neither end can talk or hear one another.
I need help with this ASAP, thanks!
05-09-2008 06:14 AM
For the traces you sent previously, can you check the media endpoints? Probably they want media to go back to you, in which case you can try configuring a voice class with media flow-through.
05-09-2008 06:16 AM
Hey thanks for the reply. I saw your post like this in another thread but I was confused on excatly what I need to do.
when you have a second could you explain in detail what i need to do and give me the commands to accomplish it?
05-09-2008 08:11 AM
Try creating a voice class with the media command, and apply on all relevant voip DPs.
05-09-2008 08:22 AM
Well this is weird. I do not have the media command available under a dial-peer, voice class, or global voice config. I only have "media statistics"
I am running IOS 12.4-15T3
Any other ideas?
Thanks for your continued help.
05-09-2008 08:33 AM
That might be because you do not have ip-to-ip gw image. In fact, for what you're doing, I suspect such image is required.
05-09-2008 08:59 AM
Keep in mind the SIP trunk I am connecting to is a Broadsoft VOIP server, not Cisco. I dont know if it matters.
05-09-2008 09:01 AM
That images is not available for the 1760.
Here are my options:
Platform: 1760
Release: 12.4.15T5 ( ED - Early Deployment )
Narrow your choices by choosing a major release.
12.4 12.3 12.2 12.1
Library
Select options from the table below to find the software you want:
Choose Options
Select Software Feature Set
ENTERPRISE BASE
ENTERPRISE SERVICES
IP/ADSL
IP/ADSL PLUS
IP/ADSL/IPX/AT/IBM/FW/IDS PLUS IPSEC 3DES
ENTERPRISE SERVICES W/O CRYPTO
ADVANCED IP SERVICES
ADVANCED SECURITY
IP VOICE
IP/ADSL/FW/IDS PLUS IPSEC 3DES
IP BASE
IP BASE W/O CRYPTO
SP SERVICES
ADVANCED ENTERPRISE SERVICES
ENTERPRISE BASE W/O CRYPTO
IP/ADSL/VOX PLUS
IP VOICE W/O CRYPTO
05-09-2008 09:03 AM
Understand.
Unfortunately I think that something is wrong with the media endpoints when a call is forwarded sip-to-sip, and I'm not sure what you can do about that.
05-09-2008 09:05 AM
I just reviewed the CME docs and I am running the correct image to support CME. It looks like the IPtoIP gateway was stopped with IOS 12.3
05-11-2008 04:19 PM
OK I have signed up for the Broadvoice bring your own device progam to test call forwarding. Guess what same problem.
I am thinking this has to be something on the CME side now.
Any other ideas?
