Routing question...
May 9th, 2008
I want to redistribute an individual static route. I don't want to redistribute all static routes I have on my router. I believe i need to use the "redistribute static route-map" command but am not entirely sure of the correct syntax. I also believe I have to first create the route-map and populate the individual route into it... once again I need some assitance on that. :)
Any help would be appreciated...
Overall Rating: 2 (1 ratings)
guruprasadr Fri, 05/09/2008 - 06:17
HI William, [Pls Rate if HELPS]
Considering for a Scenario, having the EIGRP as the Protocol:
router eigrp 873
redistribute connected route-map eigrp
network xxx.xxx.xxx.xx 0.0.0.3
neighbor xxx.xxx.xxx.xx FastEthernet0/0.873
no auto-summary
Create an Extended ACL:
ip access-list extended eigrp
permit ip host xxx.xxx.xxx.xx any
permit ip xxx.xxx.xxx.xxx 0.0.0.7 any
Create an Route-MAP & Match the Extended ACL:
route-map eigrp permit 10
match ip address eigrp
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
william.briere Fri, 05/09/2008 - 06:40
One other question...
Do you see any issue with the address that is being routed being a public IP?
Basically I am routing an individual public IP across my private network and out a different gateway :)
guruprasadr Fri, 05/09/2008 - 06:43
HI William, [Pls RATE if HELPS]
Doesn't matter, irrespective of Protocol but the Configuration style is same.
/32 Public Address can be routed very well to a different Gateway.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Richard Burts Fri, 05/09/2008 - 07:29
Guru
Using an extended access list for a route map to control redistribution makes it unnecessarily complicated. The same result can be acheived in a more simple way using a standard access list rather than an extended access list.
Rick
guruprasadr Fri, 05/09/2008 - 07:35
Dear Rick,
But "i" feel more easy upon using Extended Access-list, since i have the clear classification to control.... :-)
Thanks for the recommendation, i agree to your POINT.
Thanks, Guru Prasad R
petersrule2003 Fri, 05/09/2008 - 17:46
CREATE A STANDARD ACCESS LIST TO MATCH THE ROUTEE TO BE REACHED .
SET A TAG FOR D ROUTE USING A ROUTE-MAP
AND THEN REDISTRIBUTE STATIC ROUTE WITH THAT TAG SET.
