rps 2300
Answered Question
May 9th, 2008
  • Purple, 4500 points or more
We have a rps 2300 hooked to a 3560 , non E 3560. When testing it failovers fine when we pull switchpower but when we plug the switch back in it doesn't seem to automatically fall back over to wall power . I would think it would but maybe it doesn't and you have to do it via the front panel on the rps. I have read thru the whole book trying to find an answer to this. Anyone have any experience with these things ?
Correct Answer by Collin Clark about 8 years 11 months ago
Glen-
Working with the RPS's on a non-E stinks. A power cycle of the switch is required to return the power state back to the switch (official Cisco), but you can unplug the RPS cable/power cable and the switch will start using it's own power supply, however, it sometimes reboots anyways!
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 05/09/2008 - 08:22
Glen-
glen.grant Fri, 05/09/2008 - 08:48
Thanks thats what i thought just by doing testing here in the lab . I was able to get it to go back by putting the port in standby and then putting it back active . The main issue in our case is that we won't know when they flop over to the rps as we aren't doing any kind of snmp traps on the switches . Very poor design , you would think they would put the functionality in all the IOS code for the switches if they have rps capability.
