Web Auth allows non IE users full access
May 9th, 2008
Hello, We have a 2106 ver and 6 1131 AP's. There a 8 WLANs, on of them being Guest with Web-Auth enabled. According to the doc, Web Auth only works with IE. In our case, you can use other browsers (firefox, safari), but no authentication is required for access. We get directed to the login page but any credentials will give you full access. I did not find a bug for this which is supprising as it appears to be a major security hole. Do you know if this was fixed in the newer software? Is there a related bug?
Trending Topics - Security & Network
