RouteListExhausted - RTMT
May 9th, 2008
I'm seeing a Route List Exhausted in the Realtime Monitoring Tool...
I tryied to find something about what is causing the problem.. but I couldn't find ..
Any idea ?
Thanks.
Andrei.
Adam Thompson Fri, 05/09/2008 - 07:28
What is contained in the route list that is being exhausted? If they are, for example, an outbound PRI group, then maybe you maxed out your PRI channels.
-Adam
Please rate post if helpful.
