How can I find out which services are running?
Answered Question
May 9th, 2008
Is there a command I run on any router on switch that will show me a total list of what services I have running e.g. dhcp, finger, http etc..
Dan
Correct Answer by guruprasadr about 9 years 2 months ago
HI Dan, [Pls RATE if HELPS]
Below provided the Command:
Router#sh processes cpu ?
history Show CPU history in graph format
sorted Show sorted output based on percentage of utilization
| Output modifiers
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Overall Rating: 5 (1 ratings)
Correct Answer
guruprasadr Fri, 05/09/2008 - 07:01
  • Gold, 750 points or more
| Output modifiers
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Collin Clark Fri, 05/09/2008 - 07:44
  • Purple, 4500 points or more
Check out this command too, show ip sockets.
