fxo config issue
May 9th, 2008
I am trying to configure a FXO port on CCME 4.1
Calls are coming in o.k but when I disconnect the call from the Callmanager express side, the other party stays connected.
Also I cannot make outgoing calls, I have pasted the relevant detaills below.
dial-peer voice 9 pots
description - Mobile -
destination-pattern 907.........
port 0/0/0
forward-digits 11
voice-port 0/0/0
signal groundStart
cptone GB
connection plar opx 3006
impedance complex2
Overall Rating: 3 (2 ratings)
silex Fri, 05/09/2008 - 09:05
thanks for the info but I have read ittried that and still no joy, the main concern is not being able to dial out at all
Paolo Bevilacqua Fri, 05/09/2008 - 09:54
May be the port is stuck due to a call remained up. Reload the router and see if you're able to call out.
silex Fri, 05/09/2008 - 10:17
yes I have done that as well.
when i run a sh voice port summary whilst dialling out, I can see the fxo port go off hook
but then nothing happens i do not get any sound
Paolo Bevilacqua Fri, 05/09/2008 - 10:29
Is the line active ? Check with a phone.
Beside, if not active, the routerl will tell you that as "power denial" with "debug vpm signal" and "term mon".
silex Fri, 05/09/2008 - 11:59
I have also tried with an analogue phone and it can make outgoing calls, what I have done is completely wipe the config and just used the bare min config with one phone registered, that has worked fine, so obviously i have some misconfig somewhere, I will add a bit at a time
and see wht happens,
many thanks for your help
