IS-IS routing on 2851
mmasis
Level 4
Level 4
Hello! Does somebody can tell me if the 2851 supports 12 IS-IS multi-task?
Thanks in advance.
5 Replies 5
Harold Ritter
Milady,
Do you mean 12 isis instances? Could you please clarify your question.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Yes, excuse me. 12 multiareas.
Milady,
The limit for the number of different areas you can have is 29.
Please refer to the following document for more information:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t5/ismarea.htm
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks, Yes I just found another link too, where says the 2851 has a base of 8.
http://www.cisco.com/en/US/docs/ios/solutions_docs/telco_dcn/tlcsonet.html#wp1303453
I thank you for your time!
Milady,
This is not a hard limitation but rather a general recommendation for the given platforms. The only hard limitation 29 processes derived from the number of process data blocks (PDBs) available on the box.
12 areas should be no issues depending on how many routes you have in each area of course:
Enter configuration commands, one per line. End with CNTL/Z.
2851(config)#router isis un
2851(config-router)#net 49.0001.0001.0001.0001.00
2851(config-router)#router isis deux
2851(config-router)#net 49.0002.0001.0001.0001.00
2851(config-router)#router isis trois
2851(config-router)#net 49.0003.0001.0001.0001.00
2851(config-router)#router isis quatre
2851(config-router)#net 49.0004.0001.0001.0001.00
2851(config-router)#router isis cinq
2851(config-router)#net 49.0005.0001.0001.0001.00
2851(config-router)#router isis six
2851(config-router)#net 49.0006.0001.0001.0001.00
2851(config-router)#router isis sept
2851(config-router)#net 49.0007.0001.0001.0001.00
2851(config-router)#router isis huit
2851(config-router)#net 49.0008.0001.0001.0001.00
2851(config-router)#router isis neuf
2851(config-router)#net 49.0009.0001.0001.0001.00
2851(config-router)#router isis dix
2851(config-router)#net 49.0010.0001.0001.0001.00
2851(config-router)#router isis onze
2851(config-router)#net 49.0011.0001.0001.0001.00
2851(config-router)#router isis douze
2851(config-router)#net 49.0012.0001.0001.0001.00
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
