05-09-2008 07:33 AM - edited 07-03-2021 03:50 PM
We have a autonomous wireless setup with a WLSM and WLSE. I have an issue with where I have 2 wirless clients that need to communicate using a multicast address for an application to work.
The clients can ping each other but the multicast stream is not working between the clients. The SSID is part of a mobility group that sits on a Cat 6509 sup720.
A debug on the sup720 shows the upstream multicast from one of the clients but you see no activity downstream to the other client.
Tunnel multicast stats: -
Tunnel176 is up, line protocol is up
Internet address is 53.32.176.33/27
Multicast routing: enabled
Multicast switching: fast
Multicast packets in/out: 2619/0
Multicast boundary: not set
Multicast TTL threshold: 0
Multicast Tagswitching: disabled
Sup 720 Debug: -
May 9 15:15:31: IGMP(0): Send v2 Report for 224.0.1.40 on Tunnel176
May 9 15:15:31: IGMP(0): Received v2 Report on Tunnel176 from 53.32.176.33 for 224.0.1.40
May 9 15:15:31: IGMP(0): Received Group record for group 224.0.1.40, mode 2 from 53.32.176.33 for 0 sources
May 9 15:15:31: IGMP(0): Updating EXCLUDE group timer for 224.0.1.40
May 9 15:15:31: IGMP(0): MRT Add/Update Tunnel176 for (*,224.0.1.40) by 0
May 9 15:16:15: IP(0): s=53.32.176.40 (Tunnel176) d=225.0.0.38 id=11765, prot=17, len=68(54), mroute olist null
May 9 15:16:15: IP(0): s=53.32.176.40 (Tunnel176) d=225.0.0.37 id=11766, prot=17, len=68(54), mroute olist null
May 9 15:16:25: IGMP(0): Send v2 general Query on Tunnel176
May 9 15:16:25: IGMP(0): Set report delay time to 0.9 seconds for 224.0.1.40 on Tunnel176
Please help as I need to get the 2 clients communicating using the multicast stream.
Martin
05-13-2008 07:38 AM
Are you able to change the multicast address?
I saw a similar issue with the bonjour app for macs, I changed the address to 239.0.1.100 instead of a 224.x.x.x address and that fixed it.
05-13-2008 11:23 AM
I'm unable to change the address used as it's encoded in the application and is installed on highly secured unit that has no administration account.
It's a hardware PC that is used for car diagnostics.
01-30-2009 07:24 AM
Have you enabled multicast mode on the controller ?
If so, in what mode ? Unicast or multicast ?
If you selected multicast mode, do you see the controller joining the original stream and sending it to the LWAPP distribution group to the other APs ?
