Disabling Skinni
May 9th, 2008
I just implemented ASA 5540 VPN Premium license, running on Software Version 7.2(3) and Device Manager Version 5.2(3). How can i disable skinny inspection because it is using port 2000 and this is blocking another application using the same port.
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map IPSpolicy
class IPSclass
ips promiscuous fail-open
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
inspect pptp
policy-map type inspect dns migrated_dns_map_1
parameters
I have tried to go to the class inspection_default and then no skinny inspect would won't go away. Kindly assist. Winnie.
amritpatek Thu, 05/15/2008 - 11:08
To disabled skinny inspection using commands:
firewall(config)# policy-map global_policy
firewall(config-pmap)# class inspection_default
firewall(config-pmap-c)# no inspect skinny
Skinny protocol uses port tcp 2000 which is cisco property, so the ASA by default will
inspect this port, and since it's expecting another type of traffic, it will drop the
connection. skinny is a voice protocol.So after disabling this, the asa was no longer inpecting this port and that allowed the application to run.
