CSS11506 - show flows
May 9th, 2008
Hello all,
I have a CSS11506 with the following config...
!************************** SERVICE **************************
service pas_main_uswrnsa0ptf01_11111
ip address 172.16.25.30
keepalive type tcp
keepalive port 11111
port 11111
active
service pas_main_uswrnsa0ptf02_11111
ip address 172.16.25.31
keepalive type tcp
port 11111
active
service pas_main_uswrnsa0ptf03_11111
ip address 172.16.25.32
keepalive type tcp
port 11111
active
service pas_main_uswrnsa0ptf04_11111
ip address 172.16.25.33
keepalive type tcp
port 11111
active
!*************************** OWNER ***************************
owner PAS
content PAS-pas_main-2008-11111
vip address 123.123.130.222
protocol tcp
port 11111
url "/*"
balance aca
application ssl
add service pas_main_uswrnsa0ptf01_11111
add service pas_main_uswrnsa0ptf02_11111
add service pas_main_uswrnsa0ptf03_11111
add service pas_main_uswrnsa0ptf04_11111
active
!*************************** GROUP ***************************
group PAS-pas_Dgraphs
vip address 172.16.25.11
add destination service pas_main_uswrnsa0ptf01_11111
add destination service pas_main_uswrnsa0ptf02_11111
add destination service pas_main_uswrnsa0ptf03_11111
add destination service pas_main_uswrnsa0ptf04_11111
active
I can access my servers just fine, but when issuing the 'show flows' command, I do not see my traffic... even though I can see my hit counters incrementing.
NOTE: The 'application ssl' command is something new for us, so I thought it may be related to this.
Any ideas?
-Adam
Gilles Dufour Fri, 05/09/2008 - 12:29
  • Cisco Employee,
Try
llama
flow-agent show active_fcbs
exit
Or a
show flows 0.0.0.0
Gilles.
a.veschak Fri, 05/09/2008 - 14:21
Gilles,
Still not seeing the flows.
Anything else you could recommend? Could the 'application ssl' config have anything to do with this behavior?
-Adam
Gilles Dufour Mon, 05/12/2008 - 22:49
  • Cisco Employee,
if you do not see any flow, there is no active flows !!
The flow-agent command does look at HW level for connections. If it does not return anything, it means there is no ACTIVE flow.
Gilles.
a.veschak Wed, 05/14/2008 - 12:31
Gilles,
The target IP is the content VIP 123.123.130.222 (as shown in my CSS config). However, I am testing from one of the four servers (services) associated with this content rule. Could that be causing the problem with the CSS not seeing these flows?
For example...
I am sitting on server uswrnsa0ptf01 and I test to the content VIP 123.123.130.222... and it works... but I see know flows in the CSS.
I've attached a drawing showing our network topology.
-Adam
Gilles Dufour Thu, 05/15/2008 - 04:38
  • Cisco Employee,
try to open a telnet session to your VIP IP:PORT.
Do not close the telnet session and check with a 'show flows 0.0.0.0' if you see any flow.
It should not matter if you open the connection from the server or not.
G.
