SE Standby Module disabled after IOS upgrade
May 9th, 2008
We've just loaded an IOS image on our 4510R, afterwards the standby SE is diabled and in simplex mode, is there a way to bring it online and copy the new IOS image over to the standby SE and configure redundancy.
tonygoodwin92763 Thu, 05/15/2008 - 08:28
Found the issue, the IOS version running on Active Supervisor was not able to be copied using the command copy bootflash:image_file.bin slavebootflash:image_file.bin due to lack of avialable space on the standby. I deleted the image from the standby and ran the squeeze slavebootflash: command and was able to copy the image to the standby using the copy command string mentioned above. I also ran the squeeze bootflash: command on the active supervisor and copied over the IOS image using the copy tftp bootflash: via TFTP server. Afterwards configured SSO mode redundancy for stateful switchover.
