Cant access after VPN
May 9th, 2008
My remote access client are not able to ping inside network.
my concentrator is connected with core switch.
My 172.28.31.171 is also connected in core switch. InterVLN routing is working fine. server and conncentrator is
able to reach other via core switch.
concentrator private Ip address 172.28.31.92/248
Public IP address: 208.74.112.157
VPN POOL: 172.28.31.128/248
Split tunnel is enable for 172.28.0.0/16, 172.29.0.0/16.
Routing on concentrator is
172.28.0.0/16 is connected via 172.28.31.91
172.29.0.0/16 is connected via 172.28.31.91
Core switch Ip address is 172.28.31.91
Core switch also has the route
ip route 0.0.0.0 0.0.0.0 172.28.31.85
ip route 10.0.0.0 255.255.224.0 172.28.31.68
ip route 10.11.0.32 255.255.255.224 172.28.31.68
ip route 172.28.0.0 255.255.0.0 172.28.31.68
ip route 172.28.0.0 255.255.224.0 172.28.31.77
ip route 172.28.31.128 255.255.255.248 172.28.31.92
ip route 172.29.0.0 255.255.0.0 172.28.31.68
ip route 172.31.205.224 255.255.255.224 172.28.31.68
ip route 192.168.249.0 255.255.255.0 172.28.31.68
ip route 192.168.250.0 255.255.255.0 172.28.31.68,
As u have tested you are able to connect but not able to reach anywhere, though from internal network I can ping your vpn IP 172.28.31.129.
In VPN session i can see sometimes bytes send and receive, and sometime only sending no recving.
No firewall involoved in the path between the concentrator and desired server 172.28.31.171.
Both connected on same switch but different VLAN. but Inter VLAN routing is working and both are able to ping.
ONly remote access client 172.28.31.128/248 is not able to reach anywhere.
VPN concentrator has public default filter on public interface and private filter on local interface.
Concentrator version is 4.7
rkalia1 Fri, 05/09/2008 - 17:17
What is your split tunnel policy on Concentrator? Pls let know which options are selected.
wasiimcisco Fri, 05/09/2008 - 17:21
only tunnel specified network in the list.
which are already mentioned in the post.
My lan to lan tunnel is working fine, only problem with remote access vpn tunnel. same configuration, is working fine in another office without any problem, only problem here, i have checked the configuration so many times, but everytime i found it same. dont know which thing is missing
