Cover Paths in Cisco
May 9th, 2008
How do I implement cover path (similar to Avaya) in UCM 6.
I want ext 1 to go to ext 2 then ext 3 etc... As a final step it needs to go to the voicemail of ext 1 (The original extensiln.) if all else fails
This feature in Avaya is called cover path. Do you do that in Cisco?
Thanks.
Overall Rating: 5 (1 ratings)
iec1088407 Fri, 05/09/2008 - 13:45
you can use a hunt group, and in the line instead of mark the voicemail, you write the number of the hunt group
regards.
Rob Huffman Fri, 05/09/2008 - 17:01
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ty,
In this case you could use the Forward No Answer setting FNA (under Directory Number config) so;
Ext 1 FNA Ext 2
Ext 2 FNA Ext 3
Ext 3 FNA Voicemail Pilot #
The default behaviour for Unity and most other voicemail systems would then route this call back to the voicemail box for Ext 1
Hope this helps!
Rob
ty.masse Thu, 05/15/2008 - 18:19
Rob on your proposed solution, would I have to do that on each DN one at a time? Or can you do it in one location?
IEC, your answer is intriguing about the hunt group. Can you please let me know how to send that call to the Voice Mail box of the first extension as a last resort?
I appriciate both of your answers.
Thanks.
ty.masse Thu, 05/15/2008 - 19:28
Hallelujah! I think I've found the answer. I haven't tested it yet, but I'm confident of the concept of the solution.
For anyone else's benefit who might run into that issue, here it is.
1. On the DN configuration, set the CFNA to a Hunt Pilot.
2. Alos on the DN configuration, Set Call Forward No Coverage to Voice Mail
3. Configure a Hunt Pilot and set the CFNA setting for the hunt pilot to personal preferences.
Result:
1. Phone Rings
2. After the amount of rings in seconds expires, the CFNA setting is checked, and the call gets send to the hunt pilot.
3. The hunt pilot processes the hunt list, if no one answers after the last DN in the Hunt Group, or it timesout it will check the CFNA settings for the hunt pilot.
4. That setting should say Use Personal Preferences which will cause the Hunt Pilot to check the Call forward No Coverage settings of the original DN; and that setting should be voice mail.
While this configuration is not as streamlined as the Cover Path Settings in Avaya, the end result will be exactly the same. As a matter of fact, you can do more cool stuff with internal and external number settings.
Ty
Rob Huffman Fri, 05/16/2008 - 05:41
  • Hall of Fame,
    Founding Member
Hi Ty,
You are most correct and one of the few people that has ever figured out what the "Personal Preferences" setting was designed for. 5 points for your good thinking here!
Take care,
Rob
