ASA 5510 and 1841 IPSEC Issue
May 9th, 2008
My name is Uriel and I have this issue:
We moved remote sites from Frame Relay to IPSEC between ASA 5510(Hub Site) and 1841(Remote Site)and everything works fine except that major applications when are left unattended they drop and the users need to reconnect. they did not have to do this when they were connected through the frame. the tunnel does not drop since they send email etc all the time and I was wondering how to make this tunnel behave similar to a frame connection so the applications do not drop after any inactivity.I was wondering if the ASA drops the applications some how but have not been able to determine why.
Thanks for the help,
rkalia1 Fri, 05/09/2008 - 17:53
IPSec peers have SA lifetime configured. Default is I think 86500 secs. You may need to increase that to maximum value.
