Internetworking Frame-relay with l2transport over mpls
May 9th, 2008
Hi Folks,
I am trying to transport L2 info. for frame-relay from one site to another through L2transport over mpls. But as soon as i apply xconnect to pw-class i get an error: "mpls encap is not supported on this circuit"
R1<------frame-relay----->R2<----MPLS------>R3<-------MPLS------>R4<------frame-relay----->R5
Configuration:
R1:
int s2/1
ip add 10.1.1.1 255.255.255.0
encapsulation frame-relay
frame-relay map ip 10.1.1.2 101 br
no shut
R2:
frame-relay switching
int s2/1
frame-relay intf-type dce
no shut
pseudowire-class MPLS
encapsulation mpls
internetworking ip
connect Frame s2/1 101 l2transport
xconnect 4.4.4.4 101 pw-class MPLS
error : "mpls encap is not supported on this circuit"
Hardware: 7206VXR
Please advise.
Saptanshu
dara111983 Sat, 05/10/2008 - 06:43
What is the code ???
I have same working with 12.0s(31) release,
haven't tried other !!!
regards,
Dara
saptanshu Sat, 05/10/2008 - 08:07
Hi Dara,
Thanks a lot for reply.
Is my config. seems to be alright?
Saptanshu
saptanshu Sat, 05/10/2008 - 19:35
Hi Dara,
I am not able to find : xconnect peer-router-id vcid encapsulation mpls - command in the same IOS that you have suggested.
Please advise.
Saptanshu
dara111983 Sun, 05/11/2008 - 01:02
Hi Saptanshu,
The IOS 12.0s 27 and later seems to be supporting this feature!!!
This is what I see...
connect FR Serial1/0 100 l2transport
xconnect 10.10.10.102 1 encapsulation mpls
control-plane
pe1#sh ver | i Ver
IOS (tm) 7200 Software (C7200-P-M), Version 12.0(31)S, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-P-M), Version 12.0(31)S, RELEASE SOFTWARE (fc1)
6 slot VXR midplane, Version 2.1
X.25 software, Version 3.0.0.
pe1#
