DID with PRI
Answered Question
May 9th, 2008
Dear sir
I have PRI number 5205521. and DID are map on my PRI number .I m using H.323 ,i can easily call to PSTN , but when i tried to call on my internal IP phone call get disconnected automatically.
PRI number is 5205521.
DID numbers are 52087XX
My IP phones number are 8701 ,8702 etc.
i am unable to call on my IP phones.
I am attaching my Runing configuration , and debug out put, plz help me out.
I m using four number internal dial plan.
I have also tried with
voice translation-rule 1
rule 1 /2152087../ /87../
I have attached Running-config and debug .
Correct Answer by mciarfello about 8 years 5 months ago
What resolved it? Don't leave us hanging! lol
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Sat, 05/10/2008 - 04:30
Hi, I think translation rule should be:
rule 1 /^21520/ //
Haven't checked your config beside that.
Paolo Bevilacqua Sat, 05/10/2008 - 04:41
Seems fine. Check with "debug isdn q931" and "term mon" which number are you receiving. The you can also check with "debug ccapi" what happens with the call.
Jaime Valencia Thu, 05/15/2008 - 10:30
how many digits is the telco sending to you?
many of them already send the last 4 digits so you don't need to apply any translation rules
a debug would tell you that
if this helps, please rate
