easy vpn server and remote
May 10th, 2008
i have some problem i was configure
everythink is ok connection is idle
but i cant ping server from client
show crypto ipsec sa in the vpn server
shows packet decrypt but not encrypt
i use split tunnelig an rri
static router was entered in the vpn server and sh ip route shows whis route
it's config server
crypto isakmp client configuration group test
key cisco123
pool ippool
acl 106
crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
crypto map test client authentication list userauthen
crypto map test isakmp authorization list groupauthor
crypto map test client configuration address initiate
crypto map test client configuration address respond
crypto map test 10 ipsec-isakmp dynamic dynmap
it's client config
crypto ipsec client ezvpn gprs
connect auto
group test key cisco123
mode network-extension
peer x.x.x.x
xauth userid mode local
amritpatek Thu, 05/15/2008 - 12:50
  • Silver, 250 points or more
The problem is seems like that "The pushed address is not assigned" fails in the
ipsec_ezvpn test.
For the further details follow the bug CSCek39336
