MGCP registration issue without DNS server !
Answered Question
May 10th, 2008
hi all ,
i have at lab CUCM 5.1 and 2821 router iOS 14.4. i tried to register the gateway ob CCM. i dont use domain name becuase we dont have dns server. so in simple i gave hostname to the gateway "voice2" and its exactly match the device domain name configured in CCM "voice2".
the problem , see below the config. CCM address 172.16.10 , 2821 gateway address 172.16.1.15
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.16.1.10
ccm-manager config
mgcp
mgcp call-agent 172.16.1.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
--More--
when i do show ccm-manager
voice2#show ccm-manager
MGCP Domain Name: voice2
Priority Status Host
Primary Registering with CM 172.16.1.10
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 09:57:17 UTC May 10 2008 (elapsed time: 00:24:49)
Last MGCP traffic time: 10:21:55 UTC May 10 2008 (elapsed time: 00:00:11)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2 MGCP call-agent: 172.16.1.10 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled.
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
--More--
Correct Answer by Jaime Valencia about 8 years 9 months ago
Cisco IOS MGCP and Related Protocols Configuration Guide
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_mgcp_and_related_protocols_configuration_guide/xgcp_c.html
i'd advise you to read the gateways and gatekeepers book from the CCVP path for a better understanding
the only things that change between a T1 and a E1 are the timeslots, instead of 1-24 it's 1-31 and the voice port is not 0:23 but 0:15
this will get you thru most of it:
MGCP IOS Gateway (San Jose) Interactive Voice Network Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b61.shtml
Configuring MGCP and Related Protocols
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfmgcp.html
javalenc
if this helps, please rate
Overall Rating: 5 (2 ratings)
mattcalderon Sat, 05/10/2008 - 05:28
do you happen to have ssh configured? If so, ssh configuration requires a domain name. Verify that "ip domain-name" is not configured on the gateway.
MC
t-alkhalidi Sat, 05/10/2008 - 06:58
i managed now to register the gateway, but the eendpoint E1 not registired. do i have to do card tyoe to define controller. where is that its not there in docs. just one of the guys here helped me to do so. there is no full document tell u the sequence u should follow to administer E1 PRI on mGCP gateway. for example there is nothing about card type to enable controller command. what about also to configure DSP resources for the E1 channels. i have pVDM_32 what configuration should do on voice card to enable DSP for the PRI line?!.you can find docs to tell u how to configure specefic E1 configutation. but its not organized along with what u need to do on CCM. what is PRI group? and what is PRI slots. as far as i know E1 channels from 1-31 , channels 16 is D-channels , i dont know i hope i could find docs from a to z to configure or what i should first then later to configure ISDN PRI E1 with cisco call manager
Correct Answer
Jaime Valencia Sat, 05/10/2008 - 11:18
javalenc
