ospf stub area abr
May 10th, 2008
folks,
If I have a stub area and have 2 ABRs. lets say they are advertising a default route with a cost. Will the link cost connecting to the ABRs will be added to the advertised cost? How is the cost added to the advertised route? is it at ingress of a router or when the router is advertising the route?
waleed_amer Sat, 05/10/2008 - 05:04
Hi friend,
The ABR will advertise a default route with a cost of 1 this is the default and you can sets the cost of the advertised default route by (area 1 default-cost) and any Router inside the stub area will add the ingress interface cost to received route cost.
Regards, W.Amer
NAVIN PARWAL Sat, 05/10/2008 - 05:23
are you sure , cause in my case the router advertised by ABR was not appended by the link cost in a stub network and was the name what I advertised it as....
Can you confirm your answer.
Harold Ritter Sat, 05/10/2008 - 07:01
W.Amer is right. You can do a "show ip ospf border" to see the cost to the ABR that will be added to the initial cost set by this same ABR.
