HTTP Redirection in CSS 11501
May 10th, 2008
Currently clients type the url http://name.domain.com:8080 to access our application servers which are behind the CSS 11501.
can anybody give inputs as how to configure http port redirection in CSS 11501 where clients only type http://name.domain.com without mentioning the port nos.
My configuration is as given below
****************Service******************
service Server1
ip address 192.168.51.1
redundant index 65
keepalive type tcp
keepalive port 8080
active
*****************OWNER*******************
owner abc
content Link
vip address 192.168.51.200
add service server1
redundant index 55
protocol tcp
port 8080
active
Syed Iftekhar Ahmed Mon, 05/12/2008 - 00:48
  • Blue, 1500 points or more
Try the following
service Server1
redundant index 65
keepalive type tcp
keepalive port 8080
port 8080
active
owner abc
content Link
add service server1
redundant index 55
protocol tcp
port 80
active
iexsystem Tue, 05/13/2008 - 06:11
Thanks for your reply but it did not work.
Can this be done on the Pix 515 E itself.
Gilles Dufour Tue, 05/13/2008 - 12:28
  • Cisco Employee,
the suggestion that was given to you should work.
So, if it does not, some troubleshooting is required.
It's not enough to say it does not work.
A sniffer trace on the client would be a good start.
See what's going on.
Your server might be configured to send a redirect.
This would break the suggested setup.
You would need to configure the redirect on the CSS or modify the server redirect or suppress the redirect.
Gilles.
