VPN client error 56 on Vista Business
May 10th, 2008
i installed multiple times with different versions of VPN client on my vista business (IBM x61). i keep having problem to start the vpn client. sometime i can, sometimes i cannot.
error 56.
JORGE RODRIGUEZ Sat, 05/10/2008 - 20:27
you may want to do a search on main forum or google on error 56 to find a solid fix for issue, I have seen this report like yours mostly in systems runing vista OS so it seems the common denominator may not be cisco vpn client but vista itself, I would suggest to goodle this error and see what other have done to get by.
here is one thread found in google
http://www.lamnk.com/blog/vpn/error-56-the-cisco-systems-inc-vpn-service-has-not-been-started/
Fernando Patzlaff Tue, 07/20/2010 - 12:01
A coleague found this script to recreate the service and solve this problem. The VPN Client worked fine after run this script.
createservice.bat
@echo off
echo *********************************
echo  Installing Cisco VPN Service
sc stop cvpnd
sc delete cvpnd
sc create cvpnd binPath= "%PROGRAMFILES%\Cisco Systems\VPN Client\cvpnd.exe" start= auto DisplayName= "Cisco VPN Service" depend= DNE
sc start cvpnd
manish arora Tue, 07/20/2010 - 16:19
I have multiple issues with Cisco client and Vista os , i have contacted cisco TAC and Microsoft. Then saw the blame game among the industry leaders and had no help. since then i have been using the free ware vpn client ( compatible with cisco and understands pcf files as well ) . try using shrewsoft vpn client from shrew.net. It also works perfectly with vista/ win7 64 bit edition.
hope it helps
manish
Paolo Bevilacqua Fri, 10/12/2012 - 11:47
  1. Revise all network connections, even unused ones, to make sure sharing is disabled
  2. In services administration, make sure "Internet Connection Sharing" is set to manual.
  3. Restart PC
