switch config on poe
May 10th, 2008
WHATS WRONG WITH THE BELOW CONFIG
FINDINGS;
-WHEN PHONE IS PLUGGED TO INT F0/13, IT WAS ABLE TO REGISTER TO THE CME ON THE VG.
-SOME PORTS ON F0/1-12 WORKS FOR PHONES AND SOME JUST DONT
COMMON CONFIG OF PORTS FO/1-12
interface FastEthernet0/1
description PHONE_PC
switchport access vlan 101
switchport mode access
switchport voice vlan 601
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
CONNECTION TO THE VOICE ROUTER
interface FastEthernet0/24
description VOICE_GATEWAY
switchport access vlan 601
DEDICATED USER DATA VLAN
interface FastEthernet0/13
INT VLAN 101
IP ADDRESS 10.101.1.1 255.255.255.1
INT VLAN 601
NO IP ADDRESS
interface FastEthernet0/24 IS CONNECTED TO THE VOICE ROUTER HAVING THE VG IP ADDRESS OF 10.61.1.1
Overall Rating: 4 (1 ratings)
Rob Huffman Sat, 05/10/2008 - 08:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Celso,
Hope all is well with you :)
I would try removing this line from the Ports that connect to IP Phones;
It is unnecessary to configure the switchport in Trunk mode because when you use the Voice VLAN (with a native vlan) command a "special" dot1q trunk is automatically setup. The reasons I have seen to support this setup are many and vary from minimizing Trunking overhead to ease of configuration and everything in between :) On the older 3500XL Switches the Trunk method was the only way to go, but on all newer versions the need for Sitchport mode Trunk is not necessary. Here is one of the better threads I have ever read on this issue (with some Tac links as well). There are some great answers from Mahesh,Paolo Sankar and others here.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddd5905/14#selected_message
This good link was kindly provided by Jaime;
How to configure a Catalyst switch port to connect to a Cisco IP phone
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K33524366
Hope this helps!
Rob
cfajardo1_2 Sun, 05/11/2008 - 06:59
with the port connection to the voice gateway, do we realy need to configure
- switchport access vlan 601
Rob Huffman Sun, 05/11/2008 - 07:03
  • Hall of Fame,
    Founding Member
Hi Celso,
For that port I think you could actually delete these two lines;
Hope this helps!
Rob
shaw.chris Tue, 12/02/2008 - 06:42
Does Auto QOS need to be set up on the switchport that connects to the CME Router?
