VPN Client cant Ping
May 10th, 2008
Client is able to connect without any problem, but client not able to ping or connect with any network device.
In VPN session i can see bytes send and receive. My LAN-2-LAN tunnles are working fine without any problem.
No firewall involoved in the path between the concentrator and desired server
Both connected on same switch but different VLAN. Inter VLAN routing is working and both are able to ping.
ONly remote access client is not able to reach anywhere.
Core switch routing table
ip route
ip route
ip route
ip route
ip route
Concentrator routing table via via via via via
Split tunnel is enable for
wasiimcisco Sun, 05/11/2008 - 10:19
no body is replying to me that is the reason i post it on multiple places, but still the problem is there and no solution.
