UTA Continuously running
Answered Question
May 10th, 2008
I'm using LMS2.6 with CM4.0.10. From last week the UT Acquisition schedule process showing in running state continuously for more than 24 hours. We are having nearly 4500 end hosts.
[Previously it used to take 30 min (LMS2.5), from last one/two months it was taking 2 hours.]
I have restarted the server but still same problem. All processes seems to running normal.
Can anyone help please..
Correct Answer by Joe Clarke about 8 years 8 months ago
No. The DCR data is stored in the cmf database. You will only lose Campus Manager-related data.
Overall Rating: 5 (1 ratings)
Joe Clarke Sat, 05/10/2008 - 23:25
Please post the output of the pdshow command as well as the ut.log.
Joe Clarke Sun, 05/11/2008 - 10:19
There appears to be a problem with the ANI database. If you have a known good LMS backup, it might be time to restore it. Else, you will need to reinitialize the ANI database then run a new Campus Data Collection, then a new UT acquisition. To reinitialize the ANI database, run the command:
C:\PROGRA~1\CSCOpx\bin\perl C:\PROGRA~1\CSCOpx\bin\dbRestoreOrig.pl dsn=ani dmprefix=ANI
aijaz802 Sun, 05/11/2008 - 21:41
Hi Clarke,
By reinitializing the ANI database do I lose DCR data?
Correct Answer
Joe Clarke Sun, 05/11/2008 - 21:58
aijaz802 Sun, 05/11/2008 - 22:11
Daemon manager is running ...
Daemon manager must be shut down before running dbRestoreOrig.pl
Whats the next step?
