Policy based routing example
May 11th, 2008
At present I have one central router where 2 line is connected . one of ISP (A) is connected to internet and other is connected to Branch office. Now all net realted data www, smptp, ftp are go through ISP (A).
I want to do:
Now another ISP (B) is connected my router. I want from specific IP or Proxy IP address request www through ISP 3 and rest of data smtp, ftp ,others rquest process via ISP 2. But if any of ISP line A or B is down then all data pass alive ISP and when two ISP is come back normal then data request previous condition.
I think anyone help me full fill this sceniro with the example.
thanks
Biplob
izackvail Sun, 05/11/2008 - 15:06
Hi Biplob, you could use an access list to match the type of traffic that you are wanting to policy route and then a set command to point it at the next hop ISP that you want. This would work best if you were running some kind of a dynamic routing protocol because if the next hop you specify goes down the router will ignore the route map and route the packet normally.
For example:
access-list 101 permit tcp any any eq www
route-map NEXT_HOP
match ip address 101
set ip next-hop 10.1.1.1
int f0/0
ip policy route-map NEXT-HOP
You could also try using the set interface command. You could do something like:
route-map NEXT_HOP
set interface serial0 serial1 serial2
The router will use the first available interface in the list.
iqbalkhan Mon, 05/12/2008 - 22:34
I mistype .correction is regarding ISP A B C=
At present I have one central router where 2 line is connected . one of ISP (A) is connected to internet and other ISP (B) is connected to Branch office. Now all net realted data www, smptp, ftp are go through ISP (A).
I want to do:
Now another ISP (c) is connected my router. I want from specific IP or Proxy IP address request www through ISP C and rest of data smtp, ftp ,others rquest process via ISP A. But if any of ISP line A or C is down then all data pass alive ISP and when two ISP is come back normal then data request previous condition.
iqbalkhan Mon, 05/12/2008 - 22:42
Hi IZA
Thanks your example.
in your example you shows permit all IP.
BUT if if I permit from specific IP request www through ISP C then just change the ACL.
like if my pc IP is 203.113.178.5 and next hop is 10.1.1.1
then I just edit:
access-list 101 permit tcp any 203.113.178.5 eq www
route-map NEXT_HOP
Pls let me know
thanks
biplob
izackvail Tue, 05/13/2008 - 05:17
Hi Biplob, it looks like you are on the right track except that access-list would route anything destined for 203.113.178.5. I think you want anything sourced from 203.113.178.5 with a desination port of 80 don't you? That would look like this:
access-list 101 permit tcp 203.113.178.5 any eq www
Either way I think you have the right idea.
