Edison Ortiz Sun, 05/11/2008 - 09:18
  • Hall of Fame,
    Founding Member
Yes, it will work.
Hub
Rack1R1#sh run int s1/0
Building configuration...
Current configuration : 242 bytes
interface Serial1/0
ip address 192.168.123.1 255.255.255.0
encapsulation frame-relay
serial restart-delay 0
frame-relay map ip 192.168.123.2 102 broadcast
frame-relay map ip 192.168.123.3 103 broadcast
no frame-relay inverse-arp
Spokes:
interface Serial1/0
no ip address
interface Serial1/0.123 point-to-point
ip address 192.168.123.2 255.255.255.0
frame-relay interface-dlci 201
interface Serial1/0
no ip address
ip address 192.168.123.3 255.255.255.0
frame-relay interface-dlci 301
Verification:
Pinging from spoke to spoke
Rack1R3#ping 192.168.123.2
Sending 5, 100-byte ICMP Echos to 192.168.123.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/136/308 ms
Rack1R3#
Rack1R2#ping 192.168.123.3
Sending 5, 100-byte ICMP Echos to 192.168.123.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/112/220 ms
Rack1R2#
Pinging from hub to spokes:
Rack1R1#ping 192.168.123.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/60/140 ms
Rack1R1#ping 192.168.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/69/180 ms
Rack1R1#
HTH,
__
Edison.
NAVIN PARWAL Sun, 05/11/2008 - 09:57
Edison,
Will this work if you had a multipoint subinterface at the hub instead of a physical interface?
mahmoodmkl Sun, 05/11/2008 - 10:49
  • Gold, 750 points or more
I think it doesnt make any difference if u r going with this setup.
Mahmood
bvsnarayana03 Sun, 05/11/2008 - 11:31
  • Silver, 250 points or more
You can work the way you want, only the L2 - L3 mappings should be perfect.
Edison Ortiz Sun, 05/11/2008 - 11:39
  • Hall of Fame,
    Founding Member
multipoint subinterface has the same behavior as a physical main interface, the only difference is that you can have multiple multipoint subinterfaces while you can only have one physical interface.
HTH,
__
Edison.
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
