05-11-2008 03:01 AM - edited 03-05-2019 10:53 PM
Can any one advice what is this error causing under eigrp.
*May 11 10:34:57.595 GMT: EIGRP: Packet from ourselves ignored
05-11-2008 04:00 AM
It appears that you have received an EIGRP packet whose source address is one of its own interface addresses. EIGRP ignores the packet. I believe that I have seen similar scenario when a router running EIGRP was connected to a hub and some user connected two of the hub ports to each other. So the router sent out EIGRP packets to one hub port and received the packet back from the other hub port.
Rick
05-11-2008 04:57 AM
Rick,
This would also be normal if the loopback interface network address is configured under the eigrp process and that the loopback interface is not configured as "passive-interface"
05-11-2008 01:36 PM
Harold
Thanks for adding this point. It would certainly be the more common reason for seeing the message.
Rick
05-11-2008 09:30 PM
HI,
The loopback is added under eigrp, also there is no hub connected. How can I traceout the same source if its routing through eigrp.
Eldo
05-12-2008 12:46 AM
Eldo
if its the loopback address then put that interface into passive mode ..this should put an end to the messages.
Sol
