amritpatek Fri, 05/16/2008 - 13:38
You need to go into regedit.exe and do a search on "vpn" under the
HKEY_LOCAL_MACHINE. Now you need to start deleting things that look like
they go with the VPN Client. The logical part of doing this was the
instructions that you already followed. Now we are into the illogical
uninstall steps.
SAVE THE REGISTRY FIRST AND CREATE A BACKUP START DISK.
Here are the basic rules:
1) If it says Cisco and looks like there's only Cisco stuff in the
folder, delete the folder. Search the registry for the following items:
Cisco
CVPND
CVPNDRA
Ipsecdialer
Vpngui
Vpnapi
Under "Components" or "Uninstall" folders, delete the randomly named
folder entirely if it has Cisco in it.
2) If it says Microsoft or RAS, don't delete it. Don't delete any
folders under "Network".
3) If the file or folder won't delete, don't worry about it. LEGACY
items won't delete.
Now this sounds barbaric but the problem is that since every machine has different patches, applications, and drivers installed, we don't know where the installer put all of the VPN Client links. So we have to search them out. Normally the link they followed hits enough to allow an upgrade. In some cases it doesn't.
