05-11-2008 07:32 AM - edited 03-03-2019 09:54 PM
Hi All
I have a lightstream 1010 ATM router which has a 25 pin Console port. I was wondering if anybody would be able to tell me the pinout required to make up a DB25 pin adapter which I can connect to the octal cable of a 2511 to allow me set up reverse telnet?
If you could give me the color of the cable that goes to pin 1, pin 2 etc it would help a great deal as I have DB25 to RJ45 adapters which I can make up myself.
Best Regards & TIA,
Michael
Solved! Go to Solution.
05-11-2008 08:13 AM
My mistake:
Here's the link to the pinout:
Please disregard my first post (and curse Cisco's lack of editing capability)
2, 3, & & would probably work, but you'd likely have to also tie up all the handshake lines from the DTE side.
Good Luck
Scott
05-11-2008 08:05 AM
It should use only pins 2, 3, and 7.
2&3 are transmit/receive, pin 7 is signal ground.
Remember to set your terminal program for 9600, 8, N, 1, no flow control (no software control, no hardware control).
Good Luck
Scott
05-11-2008 08:13 AM
My mistake:
Good Luck
Scott
05-13-2008 06:44 AM
Hi Scott
Thanks for the response and the link, Much Appreciated. Worked a treat.
Best Regards,
Michael
