Unity Message Store Wizard location
Answered Question
May 11th, 2008
  • Silver, 250 points or more
I would like to re-run this but if I run the Unity Install it won't let me run without reinstalling unity. Where is the .exe for the wizard located so I can run it please.
Chad
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Chad,
Good question! Can you try this;
Run the Message Store Config Wizard through ...\CommServer\ConfigurationSetup\Setup.exe.
http://www.cisco.com/application/pdf/paws/42945/unity-sa-trblshoot-guide.pdf
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Sun, 05/11/2008 - 11:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chad,
Hope this helps!
Rob
Rob Huffman Sun, 05/11/2008 - 12:10
  • Hall of Fame,
    Founding Member
Hi Chad,
You are most welcome!
Take care,
Rob
