Aironet 1252g slow performance
May 11th, 2008
I have a Cisco Aironet 1252g setup and I have 2 PCs using linksys N adapters connecting to it. Speed is comparable to G. Is there something special I should be doing to improve the speed. I setup the AP within line of site and only about 50 feet away and the speed is still poor.
Scott Fella Sun, 05/11/2008 - 17:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What is your Linksys speed showing? If it shows 54 Mbps or less, then yes you will have comparable speeds since you are not running 'N'.
You might have to verify that you have 40Mhz channel width and the other necessary configurations.
Scott Fella Mon, 05/12/2008 - 11:37
  • Hall of Fame,
    2017 Wireless
Then you have to configure the ap to use the 40mhz channel width and you will be good to go.
j_Pearcy00 Wed, 05/14/2008 - 14:51
ok I have got the speed issue taken care of but I cannot get the AP to run at the N data rates unless its not encrypted. I see these messages from the AP: Interface Dot11Radio0, Mcs rates disabled on vlan 0 due to not using AES encryption or encryption is not disabled . The only way I can see to use AES is to use AES CCMP. Is there a way around this?
Scott Fella Wed, 05/14/2008 - 15:57
  • Hall of Fame,
    2017 Wireless
WPA is not supported.... Use WPA2 with AES and you will be good to go.
j_Pearcy00 Wed, 05/14/2008 - 16:22
The only options for ciphers are:
wep 128
wep 40
TKIP
CKIP
CMIC
CKIP-CMIC
TKIP+WEP 128
TKIP+WEP 40
AES CCMP
AES CCMP + TKIP
AES CCMP + TKIP + WEP 128
AES CCMP + TKIP + WEP 40
There is no plain old AES
Scott Fella Wed, 05/14/2008 - 16:24
  • Hall of Fame,
    2017 Wireless
Try AES CCMP.... I guess this is autonomous AP?
j_Pearcy00 Wed, 05/14/2008 - 17:07
this is autonomous ap yes. AES CCMP requires Radius?
Scott Fella Wed, 05/14/2008 - 17:28
  • Hall of Fame,
    2017 Wireless
Can't find the info on autonomous but you might try this:
ap# configure terminal
ap(config-if)# ssid
ap(config-ssid)# wpa2-psk ascii
ap(config)# interface dot11radio 0
ap(config-ssid)# ssid batman
ap(config-if)# exit
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/12_4_10b_JA3rn.html#wp291685
j_Pearcy00 Thu, 05/15/2008 - 06:00
Yeah that dosent work. Everything that I read says that AES CCMP requires radius. There is no option for just AES only AES CCMP
Scott Fella Thu, 05/15/2008 - 09:27
  • Hall of Fame,
    2017 Wireless
I guess the code doesn't yet support WPA2-PSK. I know for sure that it works in an lwapp environment. Weird that you can't configure that. All other options will require a radius server though.
cuevas Tue, 02/10/2009 - 14:09
I did this as well, and my PCs seem to be better, but the MACs are still having issues. I'm using my 1252G Access Points as LWAPP with a WLC 4402.
ericgarnel Wed, 02/11/2009 - 07:09
  • Gold, 750 points or more
Have you enabled wwm allowed or required under the wlan QOS tab?
cuevas Wed, 02/11/2009 - 09:15
I have the wmm set to allowed on the Data SSIDs, and its set to Required on my SSID for Voice
