CCX Angent Q owerflow
Answered Question
May 11th, 2008
I am making a CCX install and i will like to have 2 service Q's. Q1 and Q2 8different agents). The Q1 has the trigger on it. If no Agents is taking the call after 90 sec i will like this call to be forwarded to Q2 on the Q2 Trigger or som other way.
I am testing this on the sample ICD script but i can figure out how to do this in the editor. pls. help
Attached is the sample icd script .
Best regards
Soren Knudsen
Correct Answer by Chawki Salhi about 9 years 1 month ago
I would advise you to do the following:
-in the select ressource step: on the queued branch use the step:
get reporting statistic step. On this step, take the stat: current wait duration (see the script guides)
Once you have that data, just compare it to 90 and if it is greater, then use step:
redirect call to the other trigger.
Best regards,
Chawki
Overall Rating: 5 (1 ratings)
Correct Answer
Chawki Salhi Tue, 05/20/2008 - 07:25
Best regards,
Chawki
knudsen-s Tue, 05/20/2008 - 09:16
Thanx for this, I have got it to work but on a different way with a if loop and a subscript / de Q.
But the wait you have got an idee thanx .
/soren
