EtherSwitch Problem
Answered Question
May 11th, 2008
  • Silver, 250 points or more
I have a lab setup where I have a 3845 router with a 4-port POE HWIC. I have a problem getting a phone to trunk to its pc port. I've tried a 7911 and 7961 IP phone. I assigh a voice vlan and an access vlan to the same port and it doesn't work at all. I read some documentation saying I had to configure the port as a trunk so I tried that and the voice vlan worked but the data vlan didnt pass through to the pc port. I hooked up a 2960 to the router and used the same commands and got the data and voice vlans working. Is this a bug with the EtherSwitch models? Does anyone know of a workaround?
Correct Answer by mahmoodmkl about 9 years 1 week ago
can u try by configuring the data vlan as the native vlan on that port.
Mahmood
Overall Rating: 5 (2 ratings)
Correct Answer
mahmoodmkl Sun, 05/11/2008 - 22:04
  • Gold, 750 points or more
Mahmood
Giuseppe Larosa Wed, 08/13/2008 - 08:49
  • Hall of Fame,
    Founding Member
Hello Brian,
etherswitch modules support pre-standard Cisco proprietary PoE.
when connected to the etherswitch port was the phone powered on correctly via PoE ?
when adding the trunk have you allowed on the trunk the voice and data vlan ?
I would try this:
int fasx/0
switchport
switchport trunk enc dot1q
switchport trunk allowed vlan 10,20
switchport mode trunk
switchport voice vlan 20
Hope to help
Giuseppe
Brian Meade Wed, 08/13/2008 - 15:32
The phones powered correctly via the PoE. Setting the native vlan to be the data vlan is what fixed the problem. Thanks alot guys!
