Load balancing on Cisco Router
May 11th, 2008
Dear All,
How are you doing?
Anybody Could you tell me how to configure load balancing Cisco router or Do you have sample configuration on this?
Note: All interface i used Ethernet only!!
Best regards,
Rechard_HK
spremkumar Sun, 05/11/2008 - 19:20
Hi Rechard
Can you revert back on the kinda links (VPN/Internet) on which you are planning for load balancing.
Do throw more light on the setup/topology you have in place out there..
rechard_hk Sun, 05/11/2008 - 20:41
Dear spremkumar,
I'm really sorry, i tried to find the kinda links( VPN/internet) but it doesn't see .
could you tell met the date that he post?
Best Regards,
Rechard_HK
spremkumar Mon, 05/12/2008 - 00:38
hi rechard
i was asking about the links which are getting terminated onto the ethernet ports out there.
regds
